HFDTM100GPSDATUM: Required?
Old June 5th 07, 06:57 PM posted to rec.aviation.soaring
Default HFDTM100GPSDATUM: Required?
Looking at my log from a flight recorded by my 302A, I don't see
WGS-84, as I would expect, after - HFDTM100GPSDATUM:
Is it required for FAI badge flights? A friend's 302A also shows the
same lack. Another friend carries a handheld Garmin, and his says -
HODTM100GPSDATUM: WGS-84
Will this cause a problem with FAI badge claims? (I finally finished
off my gold last weekend.
Jim (Uniform Fox)
Old June 5th 07, 10:34 PM posted to rec.aviation.soaring
There is no problem, the critical portion of the HFDTM record is the
"100", that is the specification defined code for WGS84, the rest is
informational. The reason the Garmin record starts HODTM100 is that the
"O" indicates that an Observer supplied the information (i.e. it is
manually entered), as opposed to the "F" which indicates that the flight
recorder supplied it...
Marc
Thanks! Ya' gotta' love the RAS!
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione Steve Leonard Soaring 2 September 14th 05 03:49 AM
No Medical Required [email protected] Home Built 5 April 14th 05 02:39 PM
what placards are required? Dave Butler Owning 3 June 3rd 04 09:03 PM
ADF Required Ted Timmons Instrument Flight Rules 30 April 6th 04 04:27 AM
Commercial required? Wayne Piloting 18 November 16th 03 05:36 AM
