brake reservoir installation
Old June 18th 07, 04:55 AM posted to rec.aviation.homebuilt
Default brake reservoir installation
I want to use the ACS Model A-600 brake reservoir. It's the kind that
screws directly into the master cylinder port. Because of conflict
with the pedals I'll have to put one on the right master cylinder on
the pilot's side and one on the left master cylinder on the copilot's
side. Will this setup pass inspection? Thanks
Old June 19th 07, 02:56 AM posted to rec.aviation.homebuilt
Cy Galley
Why shouldn't it!
All it has to do is work.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A 46 Year Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
2-33 brake drum [email protected] Soaring 2 June 9th 07 03:22 AM
brake fittings [email protected] Home Built 6 April 30th 07 02:33 AM
?? Mooney m20J brake fluid reservoir Russ Haggerty Owning 4 March 5th 07 06:27 PM
K21 brake parts Stuart Kinnear Soaring 10 June 26th 06 10:54 PM
looking for a 75 to 100 ton press brake about 8/10 ft Adrian eyre Home Built 1 January 6th 05 06:28 AM
