CINCINNATI – For the second time in six months, a primary
radar failure Sunday morning at Cincinnati Tower (CVG) and Terminal Radar Approach Control (TRACON) and lack of appropriate secondary radar feeds severely delayed scores of flights into and out of the nation’s 14th-busiest airport at the beginning of a morning rush hour period. It also exposed again the lack of Federal Aviation Administration action to give local CVG management the radar feeds necessary to keep the airport running efficiently in the event of power interruptions. The outage began at 7:36 a.m. EDT Sunday and by the time it ended at 10:30, 29 departing flights were delayed between 28 and 39 minutes each. Controllers instituted a first-tier ground stop, meaning Cleveland Air Route Traffic Control Center (ARTCC, or “center”) and Indianapolis Center put flights to CVG into holding patterns.There are only two long-range radar feeds into CVG, meaning that when controllers have to rely on secondary radar, they cannot “see” planes on their radar scopes that are below 5,000 feet. In those situations, such as on Sunday, Cincinnati air traffic controllers were forced to use non-radar procedures, which are based on time and distance measurements and result in 10-mile gaps between departing flights. The normal arrival rate into CVG is 108 aircraft per hour. During Sunday’s outage, that was cut to 32.“We need other radar feeds,” said Jason Hubbard, the CVG facility representative for the National Air Traffic Controllers Association. “The FAA has the ability to bring others in, but it appears to be a cost problem.” Simply put, local FAA management officials’ calls to senior FAA officials to fix the problem have been ignored. Hubbard said the FAA termed a similar radar outage in January “unprecedented” and the likelihood of one happening again was “rare.” |
In a previous article, NoneYa said:
CINCINNATI For the second time in six months, a primary radar failure Sunday morning at Cincinnati Tower (CVG) and Terminal Radar Approach Control (TRACON) and lack of appropriate secondary radar feeds severely delayed scores of flights into and out of the nation's 14th-busiest airport at the beginning of a morning rush hour period. It also exposed again the lack of Federal Aviation Administration action to But don't worry, because the airlines will still blame GA. -- Paul Tomblin http://blog.xcski.com/ ``Furthermore, [your wishlist item] would end up being the sort of system feature that we in software engineering call an "SPR generator".'' - Paul S. Winalski |
On Aug 17, 6:09 pm, (Paul Tomblin) wrote:
In a previous article, NoneYa said: CINCINNATI For the second time in six months, a primary radar failure Sunday morning at Cincinnati Tower (CVG) and Terminal Radar Approach Control (TRACON) and lack of appropriate secondary radar feeds severely delayed scores of flights into and out of the nation's 14th-busiest airport at the beginning of a morning rush hour period. It also exposed again the lack of Federal Aviation Administration action to But don't worry, because the airlines will still blame GA. -- Paul Tomblin http://blog.xcski.com/ ``Furthermore, [your wishlist item] would end up being the sort of system feature that we in software engineering call an "SPR generator".'' - Paul S. Winalski Of course it was GA's fault... all those spam cans reflect a lot of radar energy and overloaded the primary radar system causing it to go down. Then all those 1200 transponder codes overflowed the input buffer on the secondary system, causing the feed to lock up. This would be easily solved by implementing user fees. With high enough user fees, all those transponders would be turned off instead of broadcasting 1200, and the spam cans would be flying at tree top level to avoid detection, which would prevent the primary radar from going down. See, simple cause and effect... Dean W AeroLEDs LLC www.aeroleds.com |
On Aug 18, 8:02 am, john smith wrote:
In article . com, wrote: With high enough user fees, all those transponders would be turned off instead of broadcasting 1200, and the spam cans would be flying at tree top level to avoid detection, which would prevent the primary radar from going down. Dean, that was our (GA) secret. Now that you have exposed us, we will have to alter our tactics. Is that jammer you have been working on ready yet? :-) Shhhhh, its still in development, so don't tell the competition! :-) |
On Sat, 18 Aug 2007 11:50:00 -0400, NoneYa
wrote: When you use ancient technology like the FAA the comment about system overload is real and not a joke. The FAA ground DME stations routinely overload at major airports(Atlanta is real bad) because the ancient ITT equipment in the FAA facilities was only designed to simultaneously interrogate about 150 aircraft at a time. After that threshold is reached the system begins to throttle back and drop targets at the outer range of the DME equipment. In technical terms the "reply efficiency" drops. How does the system know which are the outer dme "targets"? Is it just the weaker dme transmissions that are received by the ground station that are dropped? Stan |
In a previous article, said:
How does the system know which are the outer dme "targets"? Is it just the weaker dme transmissions that are received by the ground station that are dropped? Stan By response time. It sends out a signal, and the first N to respond are tracked. -- Paul Tomblin http://blog.xcski.com/ "Whoah, whoah! A fat sarcastic Star Trek fan? You must be a devil with the ladies!" - Simpsons |
| Thread Tools | |
| Display Modes | |
