430W/When does the glideslope register
Old September 23rd 07, 08:31 AM posted to rec.aviation.ifr
scott moore
Default 430W/When does the glideslope register
Keep in mind I tried out my new 430W install for
the first time today.
I tried a few sample approaches, really outstanding.
The 430W makes you want to try full (not vectored)
approaches because it essentially automates everything.
It will hold on the approach hold, start the approach
on its own when you tell it, and fly the missed to
hold also on its own.
After trying the published approach a couple of times,
I then tried using it in a standard pattern. I wanted
to see if I could use it like a standard ILS, where the
GS becomes active on the approach. This didn't work
unless I maneuvered back behind the FAF. Attempting to
forward the approach past the FAF to the runway or
to a fix between it and the FAF worked, but announced
"approach not active", and no GS was seen.
I guess it makes sense that the GS does not go active
unless you at least fly through the FAF. Has this
been your experience with the 430W? Or is there another
way to get it to show the GS on most/all approaches,
including VFR patterns?
Thanks.
430W doubling in cost? bdl Owning 19 August 19th 07 12:11 AM
Garmin 430W holding help? Paul kgyy Piloting 1 April 11th 07 12:36 AM
Garmin 430W/530W first impressions Viperdoc[_4_] Instrument Flight Rules 9 February 27th 07 03:10 AM
GNS 430W vs GNS 480 Ron Gordon Instrument Flight Rules 66 January 4th 07 07:45 PM
Falke/T61 register Ian Walton Soaring 1 June 13th 06 10:06 AM
