Multi engine fuel crossfeed question (Duchess twin)
Old January 14th 08, 08:43 PM posted to rec.aviation.piloting
akiley
Default Multi engine fuel crossfeed question (Duchess twin)
Hi All, I'm working on my multi rating in a Beech Duchess. I'm
curious about an item that doesn't seem well covered in the POH and
elsewhere for that matter.
What if you loose one engine at altitude, allowing plenty of time to
try to fix. You determine that you ran the right tank dry of fuel.
According to the fuel diagram, you should be able to run both engines
off one tank. The fuel line exits each tank and splits: one going to
the opposite fuel selector and one going to the closest engines fuel
selector.
If this is doable, why is it not talked about more? It's not a "fix"
option on the checklist and not discussed in the text of the POH.
Crossfeed is considered an emergency operation according to the POH,
and also "level flight only". Could this be why? Possible fuel
starvation on the crossfeeding engine from maneuvering to land, where
it may be safer to feather and secure the dead engine and do your one
shot landing.
.... akiley
CFII or multi-engine? Casey Hansen Piloting 3 April 23rd 04 01:57 AM
Multi-Engine Before Commercial? David B. Cole Piloting 30 April 18th 04 05:46 PM
Time Building Multi Engine Midway Aviators Aviation Marketplace 0 March 9th 04 05:57 AM
multi engine ultralight trainers [email protected] Owning 0 January 1st 04 08:10 PM
Multi-Engine which one ? B25flyer Piloting 4 December 11th 03 07:43 PM
