Does a Garmin GPS save a track?
Old January 28th 08, 10:45 PM posted to rec.aviation.ifr
Al G[_1_]
Default Does a Garmin GPS save a track?
Hi,
Does a Garmin 530W capture a downloadable track? 496?
Al G
Old January 28th 08, 10:57 PM posted to rec.aviation.ifr
Peter Clark
On Mon, 28 Jan 2008 13:45:58 -0800, "Al G"
Hi,
I don't believe the 400 or 500 series saves tracks, but I could be
mistaken.
Old January 29th 08, 12:15 AM posted to rec.aviation.ifr
Al G[_1_]
"John Collins" wrote in message
The 500 and 400 series don't save a track for downloading. The 396 and 496
do.
Thanks, does it have some kind of common connector? USB maybe, or bluetooth?
Al G
Old January 29th 08, 12:31 AM posted to rec.aviation.ifr
tjd
I believe all the x96s use USB; the x95's and older models are RS-232
serial.
If you just want the track logs you could also buy a cheaper ($100)
non-aviation GPS - most of them store a track log (I know my 295, GPS-
V, and old GPS-12 did). I've also lamented the lack of that feature
on my shiny expensive 430W.
Old January 29th 08, 03:35 AM posted to rec.aviation.ifr
Sam Spade
do.
Al G
296, 396, 496, inexpensive Garmin to USB cable available from Garmin or
its dealers. The best bet is TVNAV.COM
Old January 29th 08, 05:14 PM posted to rec.aviation.ifr
Al G[_1_]
"Sam Spade" wrote in message
496 do.
bluetooth?
Al G
Thanks.
I've got an old yellow etrex, I could try that. I'm a CFII flying with a
guy that has
a 530W and a 496 in the aircraft. I didn't see a USB on the 496, so like you
said, it apparently requires a cable. It would be nice to display the actual
ground track after rooting around in the clouds for an hour.
Al G
Old January 29th 08, 06:51 PM posted to rec.aviation.ifr
Clay[_2_]
I used to have a Garmin 90 GPS. It kept track. Was helpful when
sending a student on a cross country. I would hide it in the
airplane and check it when they got back.
Old January 29th 08, 07:26 PM posted to rec.aviation.ifr
Sam Spade
496 do.
bluetooth?
Al G
Thanks.
guy that has
Al G
He wouldn't have the USB cable connected in the airplane.
Old January 30th 08, 04:31 PM posted to rec.aviation.ifr
Newps
The 496 has a mini USB. Lots of electronics have that now from cameras
to cell phones.
guy that has
Al G
Old January 30th 08, 04:41 PM posted to rec.aviation.ifr
Thomas Borchert
Al,
He's got that at home. IOW, it comes with the unit.
Even better: Go to www.gpsvisualizer.com, make it a KML file and load it in
Google Earth. Altitude is logged, too, by the Garmins (not by the Lowrances).
Thomas Borchert (EDDH)
Citabria Wheel track? Fortunat1 Home Built 2 September 21st 07 07:38 PM
Track Santa Barney Frank Piloting 7 December 25th 05 01:33 PM
Keeping track of students BoDEAN Piloting 7 February 28th 04 07:56 AM
Save The Lut Daniel General Aviation 0 December 7th 03 06:46 PM
Track IR ? Denis Winters Simulators 0 August 22nd 03 06:16 AM
