Quick Morning Question for SoCal Pilots-
Old April 26th 08, 04:50 PM posted to rec.aviation.piloting
EridanMan
Default Quick Morning Question for SoCal Pilots-
Hey Guys,
Bay Area Pilot, currently vacationing in Palm Springs.
I have a friend flying in later today (2:00pm) into LGB, I'm picking
her up in my PA-28-140. A Few questions:
1- FBO - Can anyone suggest an FBO that would be most convenient to
the commercial terminals at LGB? I seem to recall one that used the
same parking lot as the Commercial Building, but I was only there for
a layover a few years ago.
2- Weather - I've seen some pretty nasty visibility on the ground
because of the smog including one or two landings at LAX that were
clearly IFR in an otherwise CAVU day. The metars all look good, but
should I expect green goo anyways?
Anything else a bay area pilot should know about? I'm not
particularly worried about ATC or the busy Airspace, I have plenty of
practice with both basing at SQL.
Thanks guys!
-Scott
Old April 26th 08, 06:09 PM posted to rec.aviation.piloting
xxx
Seeing as it's a Santa Ana day (strong offshore winds), the green goo
shouldn't be a problem today. Here in the valley it's CAVU and
expected to stay that way. The winds are forecast to die down in the
afternoon, so it should be a fine day for flying along the coast.
On Apr 26, 8:50 am, EridanMan wrote:
Hey Guys,
Thanks guys!
-Scott
Old April 26th 08, 06:37 PM posted to rec.aviation.piloting
TheSmokingGnu
EridanMan wrote:
Hey Guys,
The only one that's on the same side as the terminal is the Long Beach
Air Center; they have ramps but no 100LL (they primarily service jets).
The only other one I can recommend is Rainbow Air, but they're on the
south side and I don't think they have a shuttle. If all else fails you
can hail a cab from the terminal and make the two lefts to get there.
Visibility is really only bad in the winter (mornings especially), or
when the rest of CA decides to burn the forests.
Take this from someone who is looking out the window at the tarmac: it's
clear as a bell here, 1734Z. Not a cloud to be had.
Be sure to take her out over the harbor at least once.
What's your callsign? I'll have a listen in for you on the radio.
TheSmokingGnu
Old April 26th 08, 08:38 PM posted to rec.aviation.piloting
EridanMan
Awsome! Thank you, this is exactly the info I was looking for!
May I assume the fact that the winds here in the valley are dead is
also related to the Santa Anna Winds? You guys have some fascinating
weather patterns out here (I landed at PSP in 25g35@310.... I put her
down on the numbers and easily turned off By Bravo... Might as well
been in a helicopter)
I think I'll just fill the tanks before I leave and tank the gas, that
way I can do Long Beach Air Center.
This is my NYC friend's first time every in California, I figured LGB
and then a Cherokee flight up the inland empire to the desert would be
a wonderful 'California Immersion" experience
I'm 4261J, should be overhead in about 2 hours. Thanks again for the
info!
Regards-
-Scott
On Apr 26, 10:37 am, TheSmokingGnu
EridanMan wrote:
Hey Guys,
TheSmokingGnu
Old April 27th 08, 04:42 PM posted to rec.aviation.piloting
Andy Lutz
"EridanMan" wrote in message
The winds in the Banning Pass can be E-ticket. Just north of PSP I've had my
flight bag hit the ceiling more than once. Enjoy
Quick Question about Sporty's Air-Scan V elationaviation Owning 1 September 2nd 05 01:41 AM
Ping SoCal Pilots - FAA Seminar on Mountain Flying Casey Wilson Piloting 0 August 3rd 05 06:29 PM
Quick nomenclature question jp_travers Owning 4 February 7th 05 10:38 PM
Quick Question... Ohmelads Simulators 9 October 23rd 03 12:53 AM
