Annual overdue by a few days
Old May 4th 08, 04:48 PM posted to rec.aviation.owning
Larry
Default Annual overdue by a few days
Am I allowed to fly my plane to a near by airport in order to complete
the aircraft annual even if it is a few days after annual due date? In
other words annual was done on 4/29/07 and now we are into May. What
do I need to do to get permission and how long can this extension be.
Would this be different than a "Ferry Flight" limited to 10hrs.
Or......Thanks
Larry
Old May 4th 08, 04:52 PM posted to rec.aviation.owning
Travis Marlatte
One could, if one were daring, just do the flight.
Otherwise, contact the local FSDO to get a ferry permit.
Travis
Lake N3094P
PWK
"Larry" wrote in message
Or......Thanks
Larry
Old May 4th 08, 04:54 PM posted to rec.aviation.owning
Bob Noel
Or......Thanks
Larry
I'm just an owner, but I'm not aware of any extension. It is my understanding
that If it's out of annual, then you need a ferry permit.
Bob Noel
(goodness, please trim replies!!!)
Old May 4th 08, 04:57 PM posted to rec.aviation.owning
B A R R Y
On Sun, 4 May 2008 08:48:01 -0700 (PDT), Larry
Nope.
In other words annual was done on 4/29/07 and now we are into May. What
A ferry permit, which shouldn't be difficult to get if the plane was
fully airworthy before it went out of annual. Contact your local
FSDO, or ask your mechanic if he knows a specific contact at the FSDO
to contact.
I guy who parks near me did this just last month, and it wasn't as big
a deal as I would have thought.
Old May 4th 08, 05:22 PM posted to rec.aviation.owning
Peter Clark
Or......Thanks
Get your A&P to call the FSDO and get a ferry permit. As soon as the
annual expired it's no longer legal to reposition to the other
airport. The fly-over-to-reposition provisions of the 100hr
inspection don't apply to annual inspections.
The ferry permit is basically a formality. The A&P gets one, signs
off that the aircraft is safe to move, and hands it to you to go get
the aircraft. Takes about 1/2 hour to arrange assuming the guy from
the FSDO is near his desk.
Old May 4th 08, 06:51 PM posted to rec.aviation.owning
Robert M. Gary
On May 4, 9:22*am, Peter Clark
The ferry permit is basically a formality. *The A&P gets one, signs
the aircraft. *Takes about 1/2 hour to arrange assuming the guy from
It also depends on the FSDO. Some FDSO's require basically a 100 hr
inspection before issuing the permit.
-Robert
Old May 4th 08, 07:55 PM posted to rec.aviation.owning
John Kunkel
I would think that any savvy AI would have waited and signed the annual off
on 5/1 which gives the annual a 13 month duration. (Baker's dozen)
Old May 4th 08, 08:41 PM posted to rec.aviation.owning
Mike Adams[_1_]
Peter Clark wrote in
You might also want to check your insurance to see if it's valid under a
ferry permit operation.
Old May 5th 08, 01:05 PM posted to rec.aviation.owning
John[_9_]
I would normally try to do that but sometimes the owner needs to be
legal on the first flight of his annual cycle as well as the last.
Scheduling and completion sometimes just don't work out and you end up
with a sign off on or near the last day of a month.
As for a ferry permit. The most important thing for the mechanic
arranging it is to know that any Airworthiness Directive that is
applicable is complied with prior to the ferry flight. Not usually a
big deal considering the typical low utilization of most aircraft and
a majority of ADs being based on hours but many ADs are based on
calendar time as well and that could bite if overlooked. You can fly
on a ferry permit if the inspection is overdue but you cannot normally
fly with an AD compliance overdue unless it is specifically allowed in
the AD and then the Ferry Permit has to allow for the that. So if you
apply for a ferry permit for the overdue annual and don't mention the
overdue AD then the pilot is definitely in violation.
John Dupre'
Old May 5th 08, 03:00 PM posted to rec.aviation.owning
Or......Thanks
Larry
For us Canadians, CAR 615.86 says this:
"(a) As applicable to the type of aircraft, at intervals not to expire
later than the last day of the 12th month, following the preceding
inspection, Part I and Part II of the Maintenance Schedule detailed in
Appendix B of these standards are approved by the Minister for use on
other than large aircraft, turbine-powered pressurized aeroplanes,
airships, any aeroplane or helicopter operated by a flight training
unit under CAR 406, or any aircraft operated by air operators under
CAR Part VII."
So, If I read that right, the annual for a privately-
registered aircraft must take place by the last day of the 12th month
following the last inspection. Therefore, an annual that last occurred
on, say, 12th May '07 must next be done by 31 May '08. Right?
Maybe the FARs have something similar.
Dan
old days Airman Rotorcraft 23 January 2nd 07 01:36 PM
60 Days for Calibration [email protected] Soaring 7 May 1st 06 03:00 AM
Days as a hanger rat Jack Allison Owning 33 May 12th 05 03:01 AM
Just a few more days Louis L. Perley III Owning 1 December 31st 04 01:36 PM
Two bad days... Yeff Military Aviation 0 July 3rd 04 09:31 PM
