Tolerances - Published Minimum Altitudes
Old May 10th 08, 05:03 AM posted to rec.aviation.ifr
John[_17_]
Default Tolerances - Published Minimum Altitudes
If assigned IFR altitudes can be considered to have a tolerance of +/-
200 ft before you are "busted", what applies to published minimum
altitudes other than DH and MDA on approach plates? Most people will
say that you are not supposed to descend any amount below the DH/MDA
altitudes. Does this also apply to procedure turn altitudes,
transitions etc.? Is there a tolerance that is in effect +200 -0 that
applies?
In practical terms, whereas a decent of 100 ft below an assigned
altitude will cause no problems, is such a decent of 50-100' below a
published procedure turn altitude, transition altitude enough to get in
trouble?
John
FAA regs. for minimum altitudes over built-up areas PPL-A (Canada) Piloting 16 October 16th 06 10:11 PM
Odd VSI behavior at higher altitudes Nathan Young Owning 4 August 2nd 05 11:38 PM
Picking Optimal Altitudes O. Sami Saydjari Instrument Flight Rules 20 January 8th 04 03:59 PM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 04:52 AM
Tolerances and fit. Roger Halstead Home Built 4 September 14th 03 04:14 PM
