Dittel FSG 60M available for sale
Old May 25th 08, 01:40 AM posted to rec.aviation.soaring
SF
Default Dittel FSG 60M available for sale
I have a Dittel FSG 60M radio available for sale, make an offer. The
radio was repaired last September and it worked without a problem
until Capt. Andy changed the task in the air at Cordele. It seems to
receive the beginning and the end of transmissions from the CD while
leaving out the middle part describing which task you are flying.
Parts are hard to find for these old radios and most (but not all) of
the parts in this one seem to work. If you happen to repair radios as
a hobby, or have a FSG 60M you are trying to keep going and you need a
source of parts, this is the radio for you. The original manual goes
with it.
Old May 26th 08, 04:20 AM posted to rec.aviation.soaring
On May 24, 5:40�pm, SF wrote:
I have a Dittel FSG 60M �radio available for sale, make an offer. �The
radio was repaired last September and it �worked without a problem
until Capt. Andy changed the task in the air at Cordele. �It seems to
the parts in this one seem to work. �If you happen to repair radios as
source of parts, this is the radio for you. �The original manual goes
with it.
If you don't sell it by Uvalde, I'll give you and Sam each a large hot
fudge sundae from DQ...................# 711.
Old May 27th 08, 10:32 PM posted to rec.aviation.soaring
I have a Dittel FSG 60M �radio available for sale, make an offer.. �The
with it.
Old May 27th 08, 10:34 PM posted to rec.aviation.soaring
On May 24, 5:40*pm, SF wrote:
I have a Dittel FSG 60M *radio available for sale, make an offer. *The
radio was repaired last September and it *worked without a problem
until Capt. Andy changed the task in the air at Cordele. *It seems to
the parts in this one seem to work. *If you happen to repair radios as
source of parts, this is the radio for you. *The original manual goes
with it.
Sam,
Would you trade my check that might clear for your radio that might
work?
Al Thomas
"4"
FSG 40 720 channel Dittel radio for sale goneill Soaring 1 July 18th 10 07:59 PM
Dittel FSG60M radio and cradle for sale [email protected] Soaring 2 May 9th 06 10:08 AM
For Sale Dittel Radio, Vertical Compass Card [email protected] Soaring 0 May 4th 06 11:23 PM
Dittel Joseph L. Hyde Soaring 2 July 12th 05 04:25 PM
Dittel FSG 15 A. Wolfert Soaring 0 December 18th 04 02:14 PM
