Using wing jacks on an Archer
Old June 2nd 08, 09:33 PM posted to rec.aviation.owning
Mike Noel
Default Using wing jacks on an Archer
I just got a wing jack from Aircraft Jacks and I'm trying to figure out if
I'll be able to safely use just one jack to get just one main gear off the
ground. The jack instructions assume you will use multiple jacks and a tail
weight to simultaneously lift both wings in a level attitude. Is it safe
to chock the nose and other main gear tire while just lifting one side to
change a tire or service the strut? TIA.
Best Regards,
http://photoshow.comcast.net/mikenoel
Old June 3rd 08, 05:19 PM posted to rec.aviation.owning
Stealth Pilot[_2_]
On Mon, 2 Jun 2008 12:33:02 -0700, "Mike Noel"
not safe.
the consequences of having the angled wing come off the jack will be a
ruined spar. very very expensive.
the wing has a conical jacking point that mates with a socket in the
top of the jack's push bar. it doesnt have that much retaining
ability.
jacking from the spar requires you to lift the wing for the full
extension of the oleo leg then the tyre compression ...which is a fair
distance. the wing ends up canted at an angle that makes the safety
problematic.
if you just want to jack the wheel to change tyres a better bet is to
jack under the end of the oleo. that way you just jack the tyre
compression and the jack comes nowhere near the spar.
Stealth Pilot
Headset jacks Kyprianos Biris[_2_] Products 0 April 11th 08 10:18 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 04:23 AM
Jacks Dico Owning 3 May 5th 06 07:10 AM
jacks, plugs and music on intercom Stefan Lörchner Rotorcraft 0 January 28th 06 09:09 PM
Skew-T charts on Dr. Jacks ? Doug Snyder Soaring 3 April 25th 05 08:36 PM
