Repair shop new location
Old August 8th 08, 01:25 AM posted to rec.aviation.soaring
Paul Gaines[_2_]
Default Repair shop new location
Paul Gaines of Composite Solutions has completed his relocation of his
composite aircraft repair facility to Kingman, AZ. It is a 10,000 sq ft
dedicated facility located on Flightline Drive at KIGM.
Paul A. Gaines
Old August 10th 08, 12:43 AM posted to rec.aviation.soaring
Uncle Fuzzy
composite aircraft repair facility to Kingman, AZ. *It is a 10,000 sq ft
Paul *A. *Gaines
Hi Paul,
Glad to here you're up and running in Kingman! Is there a tow plane
there?
Old August 14th 08, 07:30 PM posted to rec.aviation.soaring
Jim[_18_]
Paul *A. *Gaines
Hi Paul,
Glad to here you're up and running in Kingman! *Is there a tow plane
there?
If there are enough people, I can bring the 180 super cub out there
from Boulder City.
Jim Dingess
Old August 14th 08, 09:40 PM posted to rec.aviation.soaring
Cliff Hilty
20 minutes down the hill Joe Sheble has a pawnee at his operation at Sun
Valley Airport just south of Bullhead City/ Laughlin that gives tows,
instruction, checkrides ect. in gliders, tail draggers and seaplanes.
Quite the operation aptly named Sea, Sail, and Tail. They even have AVgas
so you can fly in and get checkouts do a bit of gambling at the AVI casino
5 minutes away and fly home!
Jim, is the Super cub yours or is there another club in Boulder?
Did you give up on the 1/4" polypro and door hinge for auto towing? : )
At 17:30 14 August 2008, Jim wrote:
On Aug 9, 3:43=A0pm, Uncle Fuzzy wrote:
his
composite aircraft repair facility to Kingman, AZ. =A0It is a 10,000
sq=
ft
Paul =A0A. =A0Gaines
Hi Paul,
Glad to here you're up and running in Kingman! =A0Is there a tow
plane
there?
from Boulder City.
Jim Dingess
Old August 14th 08, 09:55 PM posted to rec.aviation.soaring
Cliff Hilty
his
sq=
ft
Hi Paul,
plane
there?
from Boulder City.
Jim Dingess
Repair shop new location Paul Gaines[_2_] Soaring 4 August 9th 08 04:32 AM
Repair shop new location Paul Gaines[_2_] Soaring 0 August 8th 08 01:25 AM
Dittel radio repair location? Sam Discusflyer Soaring 2 July 21st 07 11:52 PM
Q: repair shop in Southern CA or AZ? Roger Worden Soaring 10 March 4th 06 10:40 AM
