"Jay Stranahan" wrote in message ... Just mildly curious, because this information doesn't seem to be available on any of the web sites I visit: What sort of gee forces were WW2 fighter aircraft built to withstand? I keep hearing stories about wings coming off in dives or very tight sustained turns -- were they *that* much more fragile than modern military craft? Depends on the aircraft The Spitfire and Hurricane were just about unbreakable being able to handle more g than the pilot but the Me-109 was known to have suffered wing tip and tail spar failures and had real compressibility issues. One of the results was that despite the theoretical performance Luftwaffe pilots were often a little more hesitant about really aggressive manoeuvering than their RAF opponents. The early versions of the Hawker Typhoon also had structural problems with the prototype actually breaking just aft of the cockpit, fortunately the pilot survived. Improvements were made but tail failures were always a problem. Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
On Wed, 04 Aug 2004 03:38:51 GMT, Jay Stranahan
wrote: Just mildly curious, because this information doesn't seem to be available on any of the web sites I visit: What sort of gee forces were WW2 fighter aircraft built to withstand? I keep hearing stories about wings coming off in dives or very tight sustained turns -- were they *that* much more fragile than modern military craft? Jay, without looking at any references, I recall that British pilots in primitive G suits were able to pull 9 Gs in the late marks of the Spitfire. That's a lot, as I understand it. Isn't the rule of thumb that a fit pilot can withstand 5 Gs? Some planes were certainly fragile. There were several cases of Japanese army Hayabusa ("Oscar") pilots shedding their wings in close combat in SE Asia in 1941-1942. And there were at least two cases where a P-40 collided with a Hayabusa wing to wing, with the result that the Hayabusa lost the wing and went down, while the P-40 flew home. I don't think they were fragile as a matter of course. The problem was that all 1930s airplanes were basically designed by guess; the fittest survived the testing process and were put into service. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com Expedition sailboat charters www.expeditionsail.com |
"tw" wrote in message . ..
"Keith Willshaw" wrote in message ... "Jay Stranahan" wrote in message ... Just mildly curious, because this information doesn't seem to be available on any of the web sites I visit: What sort of gee forces were WW2 fighter aircraft built to withstand? I keep hearing stories about wings coming off in dives or very tight sustained turns -- were they *that* much more fragile than modern military craft? Depends on the aircraft The Spitfire and Hurricane were just about unbreakable being able to handle more g than the pilot but the Me-109 was known to have suffered wing tip and tail spar failures and had real compressibility issues. One of the results was that despite the theoretical performance Luftwaffe pilots were often a little more hesitant about really aggressive manoeuvering than their RAF opponents. Wasn't this also because at least the Spit's stall characteristics were docile, whilst the 109 and 190 were rather vicious in that respect? Both aircraft were difficult though the Spitfire was marginal better in the earlier series but much better in latter. The nerve of the pilot counted for more than the differences in aircraft and at least in the early series aircraft Me 109E, Me 109F the differences in handling were not so great. The 109 had handly page automatic leading edge slats that made it possible to opperate the aircraft with high wing loading and gave a relatively benigne stall. (Handley Page and Messerschmitt swapped a nos of usefull patents) Geoffrey Welland talks of being able to hold a turn on the spit on the pre-stall "buffet" while watching an Me 109 trying to follow him, stalling and flick-rolling the other way into the ground. The Luftwaffe wern't particulary concerned with turning circle in specifying and selecting the Bf 109. The idea was to make an aircraft as small as possible with the biggest engine and therefore the highest power to weight ratio and lowest drag. In this they succeded. They also succeded in making a very easy to produce aircraft. (1/4th the labour content of the Spitfire excluding engine as its sheet metal was all 2 dimensional) Throughout the war it always maintained the abillity to perform a steep corkscrew climb that no aircraft could follow and in the early Me 109E, Me 109F and final Me 109K had a climb advantage due to power to weight ratio. However it is an airframe that in chronilogical age was more in the Hawker Hurricane era than the Spitfire. The aerodynamics became outmoded: the slats limited role rate, the ailerons became so stiff that the roll rate was only 1/4th that of a Fw190 at speeds of over 400mph and the whole airframe was too draggy. It soldiered on to long and the high wing loading meant that the aircraft couldn't grow as well as the spitfire The real reason the 109 suffered mostly was the quality of pilot training. The FW190 had a similarly nasty stall I believe and pilots were leery of hauling it around too close to the ground. For the 190A: Its strength was in a very high roll rate and a very effective engine at low altitude and its performance in the vertical. The Ta 152H, a derivative of the FW190, could out turn and out run any allied fighter though its roll rate was average. The early versions of the Hawker Typhoon also had structural problems with the prototype actually breaking just aft of the cockpit, fortunately the pilot survived. Improvements were made but tail failures were always a problem. Flutter. A very difficult problem that causes fatigue failure. The first German digital computers Konrad Zuse Z3 was used in solving flutter problems in Germany. |
Why does everyone get so bent out of shape over the Me-262? Its contemporary, the P-80 in its two-seat trainer version, is still in service as a recce and light-attack aircraft with several air forces around the world, 60 years of continuous service after its first flight. If that's not the better aircraft, or indeed the best turbojet ever built, I scratch my head as to what standards are being applied. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com Expedition sailboat charters www.expeditionsail.com |
Cub Driver wrote: Why does everyone get so bent out of shape over the Me-262? Its contemporary, the P-80 in its two-seat trainer version, is still in service as a recce and light-attack aircraft with several air forces around the world, 60 years of continuous service after its first flight. If that's not the better aircraft, or indeed the best turbojet ever built, I scratch my head as to what standards are being applied. And, of course, the Meteor is still in service too. Well, two of them are - a hybrid "T8" used for ejector-seat development and a converted F8 used for drone control system calibration at Llanbedr. The latter will leave service later this year when Llanbedr closes. Not bad for the first jet to enter service. -- Andy Breen ~ Interplanetary Scintillation Research Group http://users.aber.ac.uk/azb/ "Time has stopped, says the Black Lion clock and eternity has begun" (Dylan Thomas) |
Cub Driver wrote in message . ..
Why does everyone get so bent out of shape over the Me-262? Its contemporary, the P-80 in its two-seat trainer version, is still in service as a recce and light-attack aircraft with several air forces around the world, 60 years of continuous service after its first flight. If that's not the better aircraft, or indeed the best turbojet ever built, I scratch my head as to what standards are being applied. I don't think anyone is getting bent out of shape. The Me 262 was the first jet fighter but unlike the Meteor and P-80 the Me 262 had its development and the development of its engines cut short and interfered with by the war. The Junkers & BMW teams were way ahead in using cooling films in combustion chambers and in hollow blade cooling. They were also ahead in the use of vitrious and metallic oxide coatings. It's not right to triumphantly rubbish completely the technology and efforts of the Germans: they were ahead in many areas as well as behined. Often when they failed it was due to absence of raw materials or the problems of war time construction far more severe than the ones the allies faced. The Jumo 004 engine was actualy produced for many decades after the war in the eastern block (initialy in the junkers factories) then the Soviet Union as the RD-10 as was the BMW003 as the RD-15 and then also Yugoslavia and Czechoslovakia which used its own versions to power its trainers. Once given proper materials and improved controls it performed reliably. In France the Jumo 004 and BMW 003 were studied and fitted into the Sud-Est S.O. 6000 "Triton" and the Arsenal VG-70. Both the chief engineers of BMW and Junkers went on to designe great engines after the war for the west. The Adour of the Mirage, the T53 of the UH-1 Iroqois, T55 of the Chinook and AGT-1500 of the Abrams came from the designers of the Jumo 004 and BMW 003. I suspect that the basic Me 262 would have ended up as projected with more powerfull engines such as the HeS 011 mounted in the armpit position and remained in use as a heavy figher for quite a while. |
Cub Driver wrote:
Why does everyone get so bent out of shape over the Me-262? Its contemporary, the P-80 in its two-seat trainer version, is still in service.... If the -262 had survived this long it probably would have been a bit better than it was in 1945, too. The last time a flew a T-33 was 1971, and there were no -262s available to me for comparison. The question is, was the P-80 better than the ME-262 in 45? We'll never know, but we can say that the -262 was operational in '45, and that the -80 was not. Were German Generals better than American Generals? At least we have some basis for comparison. Jack |
On Wed, 11 Aug 2004 10:46:03 -0500, Jack wrote:
but we can say that the -262 was operational in '45, and that the -80 was not. I suggest you look a little more, the P-80 was operational in italy before the end of the war. greg -- Konnt ihr mich horen? Konnt ihr mich sehen? Konnt ihr mich fuhlen? Ich versteh euch nicht |
| Thread Tools | |
| Display Modes | |
| Rag and tube construction and computer models? | BllFs6 | Home Built | 24 | April 12th 04 01:20 PM |
| BUFDRVR - about new squadron structure | Jughead | Military Aviation | 20 | November 22nd 03 04:28 PM |
| Can F-15s making 9G turns with payload? | Paul J. Adam | Military Aviation | 114 | September 27th 03 06:47 AM |
| F-4 chaff/flare loads | Bob Martin | Military Aviation | 25 | September 25th 03 04:36 PM |
| How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 06:30 PM |
