#11
The most simple effective mouse trap . Use antifreeze in winter.
Put one in your hangar. https://www.youtube.com/watch?v=6SIlYiiCGLI |
On Saturday, June 13, 2020 at 9:28:05 PM UTC-5, George Haeh wrote:
Last year we cleaned out and restored our club G-103. For rodent proofing we: * stuffed part of a stainless steel pot scrubber around the brake hose where it comes out of the gear well * made a magnetic cover for the CG hook, and * a diaper to fit over the bottom of the the fin and rudder junction * left Fresh Cab mouse repellent in the cockpit over the winter Doing the annual after Covid19 delay, we found abundant mouse droppings in several areas along with one dead and one live field mouse caught by the vacuum. I had another look inside the gear well and discovered an open tube about an inch in diameter below and towards the center from the brake hose. Inside that tube supports the brake reservoir. Said tube now has a stainless scrubber stuffed into both ends. Perhaps the tube is there for the retraction mechanism of the earlier model. Mice will actually come after salt. Even if you eliminate foodstuffs from the cockpit the sweat in straps and belts is probably going to draw them in. |
On Friday, June 19, 2020 at 4:25:25 PM UTC-7, Shaun Wheeler wrote:
On Saturday, June 13, 2020 at 9:28:05 PM UTC-5, George Haeh wrote: Last year we cleaned out and restored our club G-103. For rodent proofing we: * stuffed part of a stainless steel pot scrubber around the brake hose where it comes out of the gear well * made a magnetic cover for the CG hook, and * a diaper to fit over the bottom of the the fin and rudder junction * left Fresh Cab mouse repellent in the cockpit over the winter Doing the annual after Covid19 delay, we found abundant mouse droppings in several areas along with one dead and one live field mouse caught by the vacuum. I had another look inside the gear well and discovered an open tube about an inch in diameter below and towards the center from the brake hose. Inside that tube supports the brake reservoir. Said tube now has a stainless scrubber stuffed into both ends. Perhaps the tube is there for the retraction mechanism of the earlier model. Mice will actually come after salt. Even if you eliminate foodstuffs from the cockpit the sweat in straps and belts is probably going to draw them in. They also want dry, sheltered places (particularly from predators) to make nests. |
Once one mouse finds a way in, every other mouse in the vicinity can/will follow the scent trail.
Rodent proofing CG Hook | George Haeh | Soaring | 14 | March 7th 19 07:21 PM |
Rodent Deterrent? | rlovinggood | Soaring | 20 | January 7th 08 05:22 AM |
Commodious Sailplane? | Jim[_6_] | Soaring | 19 | October 11th 06 04:16 AM |
Commodious Sailplane? | James Hamilton | Soaring | 0 | October 9th 06 09:37 AM |
commodious sailplane | Andy Davey | Soaring | 0 | October 8th 06 08:02 PM |
