ILS instrument accuracy? Help......
Old September 20th 03, 10:34 AM
Peter Bondar
The 'preferred' option is to have a loc frequency automatically force the
NAV/GPS switch to go to nav mode.
Almost all wiring suggestions imply that as the deafult mode.
So you barrel along with your gps upto the IAF cros tracking your favourite
VOR then swap frequencies
on nav1 and bingo your automatically lined for a loc intercept.
Personally I find it it irrating and also if P2 happens to tune the ILS/DME
for cross references
purposes and the A/P is on then you can do a beautiful intercept of the ILS
for an airfield you just
happen to be passing!!
Peter
"Stan Gosnell" wrote in message
(Ben Jackson) wrote in
news:PeIab.524381$uu5.87404@sccrnsc04:
What ACUs will allow you to select GPS display when a LOC
frequency is tuned in on the NAV? I know UPSAT's won't
actually select the GPS until you tune a normal VOR on the
associated NAV.
With the installations we have, the HSI has no idea what's
selected, or what frequency. There's a push/push button, which
cycles between VOR & GPS, and the HSI just gets voltage from
whichever is selected. There is no logic at all to prevent
using either one. The nav radios and the GPS are completely
independent, and have no relation to each other in any way.
Regards,
Stan
Old September 21st 03, 05:56 AM
Stan Gosnell
"Peter Bondar" wrote in
automatically force the NAV/GPS switch to go to nav mode.
Well, maybe preferred by some, but I may want to tune in the
localizer while I'm a long way out, getting ready for the
approach, but navigating on GPS until I'm inbound, or at least
on vectors. Forcing VOR mode just because a localizer is tuned
is simply a stupid way to do things.
Regards,
Stan
Old September 22nd 03, 08:26 PM
Maule Driver
Agreed. My Garmin 300XL is setup to force the switch and it is a procedural
pain for approaches with with course reversal.
And if you switch to NAV mode while GPS is in Hold mode, the moving map goes
a bit crazy (I guess it's looking to the indicator for intended direction
info but it's been disco'd).
May be time to go back and have it configured to 'non-preferred' mode.
Instrument panel labelling options John Galban Home Built 12 November 18th 04 10:42 PM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 02:09 AM
Most Challenging Instrument Approaches in Western US? Angus Davis Instrument Flight Rules 24 September 28th 03 09:25 AM
Got my Instrument Rating! Jazzy_Pilot Instrument Flight Rules 4 August 21st 03 02:35 AM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
