GPS approach step-down fixes
Old May 6th 06, 08:34 PM posted to rec.aviation.ifr
Default GPS approach step-down fixes
"Julian Scarfe" wrote in message ...
As far as I can see, step-down fixes on GPS approaches are always defined by
a distance to the threshold. Are there exceptions?
Do GPS approaches exist with waypoints (forming part of the approach
sequence) between the FAF and the runway threshold waypoint? Or is it
guaranteed that after passing the FAF, my distance-to-waypoint will always
be the distance to the threshold?
Counter-examples useful. References to publications guaranteeing no
counter-examples even better!
Thanks
Julian
Did you mean strictly "distance to the threshold"?
Where the Missed Approach Point is short of the threshold,
stepdown fixes are likely to be defined by distance to the MAP.
In Colorado, here are a few examples which illustrate that:
KCAG (Craig) GPS Rwy 7
KDRO (Durango) GPS Rwy 2
KEGE (Eagle County) GPS-D
KHDN (Hayden) RNAV (GPS) Y Rwy 10
KLXV (Leadville) GPS Rwy 16
KMTJ (Montrose) GPS Rwy 17, GPS Rwy 35
KRIL (Rifle) GPS Rwy 8, GPS Rwy 26
Most of those stepdown points are defined only by distance,
but at least in the case of Hayden, ZULON is a named stepdown fix,
at 1.9 nm to RAPVE, which is the MAP located 1 nm from the runway.
Old May 7th 06, 02:12 AM posted to rec.aviation.ifr
Thanks
Julian
As I said:
"The criteria are evolving and changing. You have to take each
procedure as it is charted and as it appears in your database."
Old May 7th 06, 10:27 AM posted to rec.aviation.ifr
"John R. Copeland" wrote in message
You're right, I meant distance to MAP, not distance to threshold. So
perhaps that changes the question into whether there are waypoints on the
approach between the FAF and the MAP.
OK, good example. So when I pass INEDE (the FAF) inbound on that approach,
what does my distance-to-waypoint read? 3.5, counting down to ZULON, or 5.4
counting down to RAPVE?
Julian
Old May 8th 06, 04:19 AM posted to rec.aviation.ifr
Julian
I've run several other examples through the GNS480 simulator,
and they all have computed a smooth glide path from the FAF to the MAP,
displaying nothing regarding the named stepdown fixes.
The distance counts down from the FAF to the MAP, as in your supposition.
I don't know of any approaches near me with suitable stepdown fixes
to try actually flying one for real.
But previously I've found the simulator to be very faithful to the actual equipment.
If you have the GNS430/530 simulator, try running some approaches on it.
It might behave differently, since it would not supply vertical guidance.
Old May 9th 06, 08:16 AM posted to rec.aviation.ifr
Thanks, I'll give it a go.
Julian
IFR Approach questions Roy Smith Instrument Flight Rules 2 November 7th 05 02:11 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
