Great account - Thanks.
Like all flying skills, it gets easier once a lot of the 'standard stuff' fades into background noise and you can concentrate on the challenging stuff like a waypoint called CORCE. When everything is new, it's tuff! "Wizard of Draws" wrote in message news:BDA07C40.2CCE0%jeffbTAKEOUTCAPS@TAKEOUTCAPSwi zardofdraws.com... October 23, 2004 12:00 1.6 hrs. (1.0 actual) First solo IFR, 2 approaches in actual! A warm overcast day with a slight breeze. Everything was reporting broken skies from 2200 up to 8000 where it was supposed to be overcast. A few patches of blue sky here and there made the "occasional IFR along the route of flight" that the weather briefer told me seem pretty accurate from the ground. I didn't think single pilot IFR would be stretching my abilities much with this weather, but I would learn on this flight that all is not as it looks and weather briefers are not always right. As it turned out, I would learn a lot on this flight. After my preflight, I climbed in and called for my clearance. They asked if I was ready to depart, but as I was waiting for a plane on a long downwind leg, I replied that it would be a few minutes. So they handed me off to Atlanta on another frequency for my clearance. Unbeknownst to me, it's impossible to hear ATC on that frequency on the ground at 47A. So eventually, as 2 planes piled up behind me, Randall came up to the plane and jumped in to set me straight. We taxiied across the runway to let the others take off and re-tune to 121.0 for my clearance after we told them the situation. By now, the runway and pattern were empty and they cleared me on the runway heading to 5000'. Climbing through 2500', I entered the clouds for the first time, alone. There's no turning back now. At 5000', they moved me up to 7000'. Keeping me north of my intended track for separation from traffic going into Habersham (KAJR), they finally turned me to 180 to the IAF for the GPS runway 2 at Toccoa (KTOC). Unfortunately, the IAF on this approach is named CORCE and I became confused when the controller cleared me 'to course'. As I overflew the IAF, I realized that we might have had a communications breakdown and that I wasn't sure that I was cleared for the approach. As I knew that there was another plane on the VOR approach (the opposite direction) into TOC, I didn't want to assume anything and continue in, so I started an impromptu holding pattern over CORCE and asked if I was cleared for the approach. I was starting to become very nervous at this time, since I was in the soup and making my hold pattern up as I went along. Was I going to get busted or yelled at for deviating from my instructions? The controller quickly realized the cause of my confusion and was very understanding, even to the point of wondering over the air, why they would name the fix as they did. As I finished my perfectly executed custom hold pattern and lined up to intercept the approach, he made sure I understood I was cleared all the way in to the airport. So I settled down and concentrated on keeping the needle centered as best as I could. My stickie note with my MDA written on it was attached to the panel, but I broke out into very hazy skies long before that, at about 2000' AGL. It still took a few minutes after that before I was able to pick out the runway ahead of me. I landed surprisingly smoothly and after I shut down, I went into the FBO for a while to try and relax. But not too much, because I knew I was going to have to fly through the same stuff to get home. I'd still need to be on my toes. I called Randall to let him know I was still in one piece and more importantly, so was the plane. He had followed my flight on the radio the whole time and knew exactly what had happened over CORCE, so we had a laugh about that. On the return trip, communications with ATC on the ground at TOC were impossible, but I knew that in advance, so I telephoned Clearance Delivery and coordinated my departure through them. After a short while on hold, he came back: "cleared direct 47A, climb to 5000', squawk 5114, contact Center on 134.8, void if not off by 18:20". Cool. I don't see a reason not to do it this way at 47A all the time because of the sporadic comms there. So I took off and shortly after that was level at 5000', in and out of the clouds. With about 20 miles to go, he took me down to 4000' and back into the clouds for good. Soon after that he cleared me down to 3500' and to the IAF at 47A. Since I've done this one a number of times, my stress level wasn't nearly as high as the approach into Toccoa, but I *was* still in the clouds so I tried to make and effort not to get too confident. At the intersection of the 'T' I turned in on the runway heading and a couple of miles later, I was again under the clouds in pretty thick haze. Follow the needle and there was the runway right in front of me, so I canceled IFR and set it down pretty firmly this time. I learned *a lot* on this flight. Although I was able to handle this flight, during the confusion over CORCE I was nearly saturated, if only for a short time. The controller was very busy and I had to make up my mind quickly about what I was going to do while waiting for clarification from him. A holding pattern was the only safe option I could think of with the other planes I knew of in the area. I would have realized sooner what he meant by "to CORCE" if I had studied the plate better. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com http://www.cartoonclipart.com |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 06:40 PM |
| Pilot Error? Is it Mr. Damron? | Badwater Bill | Home Built | 3 | June 23rd 04 05:05 PM |
| Best Single Pilot IFR Plane | Charles Talleyrand | Instrument Flight Rules | 64 | December 9th 03 08:20 PM |
| single pilot ifr trip tonight | Guy Elden Jr. | Instrument Flight Rules | 187 | November 24th 03 11:18 PM |
