AutoGas fueling tips and tricks
Old November 26th 07, 05:21 AM posted to rec.aviation.owning
Al[_2_]
Default AutoGas fueling tips and tricks
We have an autogas STC for our Cessna 172. Other than building another
"mighty Grape" like Jay Honeck's, what tips are there for fueling? Type
of fuel cans, funnels, bonding, do you bond a plastic can, funnel type, etc.
Al
1964 Cessna 172
Old November 26th 07, 08:09 AM posted to rec.aviation.owning
On Mon, 26 Nov 2007 01:58:51 -0500, "MCE" wrote:
I have a Cessna 150 that I've been auto-fueling for 18 months now. I
purchased a "Mr Funnel F3" well... funnel...from Aircraft Spruce. It has a
good wire mesh screen for keeping water and crud out.
Even more important, its screen keeps water out. Friend of mine tried to fill
his Volksplane from a drum of last year's gas; the funnel filled up and refused
to pass anything through. Turns out the drum had a lot of water in it....
Old November 26th 07, 09:20 PM posted to rec.aviation.owning
Jim Stewart
etc.
Al
1964 Cessna 172
I use a pair of 5 gallon red plastic jugs
with the new no-emissions normally sealed
nozzles. The jugs are the short, squat
shape and can be lifted up and emptied into
the tank without too much strain.
I try to use the jugs only to transfer fuel
and never store it longer than 24 hours.
Old November 26th 07, 09:51 PM posted to rec.aviation.owning
Robert M. Gary
etc.
Al
1964 Cessna 172
I used to carry 5 gal jugs in the car and then used a pump to transfer
to the plane. However, that was back when I could buy FAA legal mogas.
Today the cans sit in my garage.
-Robert
Old November 27th 07, 02:27 AM posted to rec.aviation.owning
Blueskies
-Robert
Ditto here...an old section of carpet as a pad over the wing, and squareish gas cans, allowed me to put the can on the
pad, put my thumb over the spigot, and then tip the can over and place the spigot in the fuel neck, then pull my thumb
away. Pop the air vent plug and let the can drain. Never any problem, until all the so-called gasoline around here
turned out to be contaminated with alcohol...
Old November 27th 07, 04:53 AM posted to rec.aviation.owning
I've seen a couple of hangar fires caused by de-fueling.
The common denominator was plastic funnels and cans.
Metal woudl be strongly advised.
Bill Hale A&P
On Nov 26, 6:27 pm, "Blueskies" wrote:
"Robert M. Gary" wrote in ...
-Robert
Old November 27th 07, 06:00 AM posted to rec.aviation.owning
Mike Noel
Have you found a source for unoxygenated (alcohol free) unleaded gasoline?
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
If any question why we died, tell them, "Because our fathers lied."
- Rudyard Kipling.
"Al" wrote in message
etc.
Al
1964 Cessna 172
Old November 27th 07, 06:12 AM posted to rec.aviation.owning
Al[_2_]
Yes. While our area was on the EPA's hit list for a number of years
with forced "oxygenation" that was lifted about 4 years ago after a
decade of air quality compliance. We have plain old gas available. I
buy direct from a jobber/fuel distributor at their pump.
Al
Old November 27th 07, 09:13 PM posted to rec.aviation.owning
Matt W. Barrow
" wrote in message
I though metal containers contribute to static discharge hazards.
Matt Barrow
Performance Homes, LLC.
Cheyenne, WY
Old November 27th 07, 10:05 PM posted to rec.aviation.owning
Matt W. Barrow wrote:
" wrote in message
It is the other way around.
Electrostatics greatly simplified:
In general it is easier to get a static charge on an insulator than
it is a conductor, i.e. metal.
In general it is easier to remove a static charge from a conductor
than it is an insulator because the charge on a conductor is uniform
over its suface while it can be localized on an insulator.
Holding a conductive can in one hand and touching the metal of the
airframe with the other will bring the airframe and can to the same
potential.
Gas cans are supposed to be conductive.
Plastic funnels are almost never conductive and the act of pouring
stuff through a plastic funnel can generate a static charge.
Use approved gas cans, or at least metal cans, and metal funnels.
Make sure everything, you, the can, and the funnel, has made contact
with airframe metal before opening anything.
Jim Pennino
Remove .spam.sux to reply.
Anyone have Tips, tricks & notes on a C-170B Al G[_2_] Piloting 7 June 4th 07 07:47 PM
Autogas Tips and Tricks Al[_2_] Piloting 46 May 4th 07 12:54 PM
MoGas Tips, Tricks, Concerns, How To Al Gilson Owning 129 May 17th 06 09:20 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 09:21 PM
FAR Reference - Self Fueling Ben Smith Owning 8 April 9th 04 12:07 AM
