#11
On Jul 18, 1:22*pm, Uncle Fuzzy wrote:
A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. *They did a nice neat job of covering the holes, but here's the follow-up. *I removed one a couple weeks ago that had been in place for a couple months. *The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! *Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. *If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl |
On Jul 19, 8:36 pm, Darryl Ramm wrote:
On Jul 18, 1:22 pm, Uncle Fuzzy wrote: A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl xylene (xylol) is very effective at removing adhesive goo when all else fails. It's usually available in pints at the local big box hardware store. Craig |
On Sat, 19 Jul 2008 21:31:12 -0700, Craig wrote:
On Jul 19, 8:36 pm, Darryl Ramm wrote: On Jul 18, 1:22 pm, Uncle Fuzzy wrote: A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl xylene (xylol) is very effective at removing adhesive goo when all else fails. It's usually available in pints at the local big box hardware store. Hexane is good for contact cement removal, assuming its not been banned as a VOC. It was the best of a fairly unimpressive set of solvents when I needed to clean double sided tape off some mylar gap seal. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
On Jul 20, 4:56*am, Martin Gregorie
wrote: On Sat, 19 Jul 2008 21:31:12 -0700, Craig wrote: On Jul 19, 8:36 pm, Darryl Ramm wrote: On Jul 18, 1:22 pm, Uncle Fuzzy wrote: A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. *They did a nice neat job of covering the holes, but here's the follow-up. *I removed one a couple weeks ago that had been in place for a couple months. *The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! *Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. *If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl xylene (xylol) is very effective at removing adhesive goo when all else fails. *It's usually available in pints at the local big box hardware store. Hexane is good for contact cement removal, assuming its not been banned as a VOC. It was the best of a fairly unimpressive set of solvents when I needed to clean double sided tape off some mylar gap seal. -- martin@ * | Martin Gregorie gregorie. | org * * * | Zappa fan & glider pilot- Hide quoted text - - Show quoted text - Pretty sure it's 'unobtainium' now. I could be mis-remembering, but I think I used Hexane as an additive to fuel for my compression ignition engines. |
I have had good result removing all kinds of decals and "stuff" off cars and
motorcycles with "GO-JO" hand cleaner. It takes a bit of rubbing, but it is harmless to whatever is underneath. And in a hurry, I have used the Go-Jo with pumice - it may leave a slight haze, if what's underneath is not too tough. Flash "Uncle Fuzzy" wrote in message ... A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. They did a nice neat job of covering the holes, but here's the follow-up. I removed one a couple weeks ago that had been in place for a couple months. |
work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Monokote is fuelproof so run of the mill methyl and ispropyl wont work. That's what fuel is(methyl alc). Try Acetone and I recall there is a TopFlite Monokote solvent that you could probably get at towerhobbies.com. If that does not work, let everything evaporate and no longer flammable and gently use a heat gun and putty knife to scrape it off. Any remaining residue can be wet sanded off. Darren |
On Sun, 20 Jul 2008 09:11:33 -0700, Uncle Fuzzy wrote:
Pretty sure it's 'unobtainium' now. I could be mis-remembering, but I think I used Hexane as an additive to fuel for my compression ignition engines. That would have been ether, assuming you mean model engines: 40% ether, 20% castor oil, 39% kerosene, 1% amyl nitrate runs pretty well. Outside a lab I've only seen hexane sold as thinners for Evostik contact cement. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
On Jul 19, 9:31*pm, Craig wrote:
On Jul 19, 8:36 pm, Darryl Ramm wrote: On Jul 18, 1:22 pm, Uncle Fuzzy wrote: A while back I posted that I had used Monokote trim to cover some of the larger holes in my Speed Astir fuselage. *They did a nice neat job of covering the holes, but here's the follow-up. *I removed one a couple weeks ago that had been in place for a couple months. *The mylar pulled off cleanly, but left the adhesive behind, and boy howdy was that stuff difficult to remove! *Perhaps with the RIGHT solvent, it wouldn't be a pain, but the 3M General Adhesive Cleaner doesn't do much but make it gooey. *If anybody knows what sort of solvent would work better on the Monokote trim adhesive, please chime in, cause I'm sure the 'racing checker' patches made my glider faster! Oh and I forgot. "Goo Gone" citrus based cleaner will probably knock this straight off. Maybe followed by a clean wipe of 3M cleaner, acetone or toluene, etc. I've used Goo Gone to take off residue of misapplied stripes similar to Monokote. Darryl xylene (xylol) is very effective at removing adhesive goo when all else fails. *It's usually available in pints at the local big box hardware store. Craig Xylene is one of the main ingredient in the 3M General Purpose Adhesive Cleaner, and yes it does work well for many things. I think the 3M blend is pretty handy for removing stuff (including wing tape residue). However the original poster reported it did not work in this case. From the material safety data sheet the main ingredients in 3M General Purpose Adhesive Cleaner are XYLENE 30 - 60% NONANE 10 - 40% OCTANES 10 - 30% ETHYLBENZENE 5 - 20% I've been able to purchase this even in California, e.g. at my local Orchard Supply Hardware store. Darryl |
On Jul 21, 10:53*am, wrote:
Try Acetone ... BTW, standard disclaimer with all this solvent talk, try on a small patch first for compatibility... Gelcoat is pretty stable and can handle Acetone, but not sure if glider in question has polyurethane and what it would do. Once had a friend who put some solvent in wax paper cup and set in on the hood of his 280Z while he worked on some blemish. Meanwhile, this stuff ate through the cup, and then proceeded to etched the paint job on his car hood. |
Covering holes | [email protected] | Soaring | 9 | May 2nd 08 05:57 PM |
Going of ver recommended TBO | gman | Piloting | 10 | October 11th 06 05:52 AM |
Covering an ultralight wing with Monokote | Chris Wells | Home Built | 5 | January 10th 06 12:20 AM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Anywhere recommended near Rochester MN? | Dave | Aerobatics | 0 | April 1st 04 05:18 PM |
