#11
Mark Hansen wrote:
On 08/07/08 06:21, Sam Spade wrote: Terence Wilson wrote: On Wed, 06 Aug 2008 18:15:04 -0700, Sam Spade wrote: You have no idea of what ATC needs to do with you if you cancel on an IFR climnb to on-top. So, keep it simple, and stay with the IFR clearance until either above or otherwise clear of the Class B airspace. On the last two occasions ATC has queried whether I was on top yet and then asked what my intention was, I cancelled, and continued on my merry way inside Bravo. So obviously they were ok with it, but my original question stands, am I cleared into the class B after I canel in class B? If my clearance limit for the IFR climb was inside Class B I would reply, "I request a clearance to outside Class B before I cancel." It's your butt that's on the line, not their's. Or, just say "negative" when they ask if you're on top, thus forcing a clearance out of the quagmire. I'm confused about why you believe you have to lie about being on top. When asked for your intentions, why not just say "Remain IFR until clear of Class Bravo"? That would work, too. In any case, my interptretation of when I am legally on top may differ from your's. The typical kee-jerk response is to "please the controller" and report on top when just breaking out in the clear. |
Sam Spade wrote:
In any case, my interptretation of when I am legally on top may differ from your's. The typical kee-jerk response is to "please the controller" and report on top when just breaking out in the clear. You're on top when you're in conditions suitable for VFR flight. You're not on top when you break out into the sunshine, you have to be at least 1000 feet above that cloud. |
On 08/07/08 09:29, Steven P. McNicoll wrote:
Sam Spade wrote: In any case, my interptretation of when I am legally on top may differ from your's. The typical kee-jerk response is to "please the controller" and report on top when just breaking out in the clear. You're on top when you're in conditions suitable for VFR flight. You're not on top when you break out into the sunshine, you have to be at least 1000 feet above that cloud. 1000' above the cloud? As I understand the cloud clearance requirements, in Class B airspace you just need to be clear of clouds (yes, this topic is about flight within Class B airspace). -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
1000' above the cloud? As I understand the cloud clearance requirements, in Class B airspace you just need to be clear of clouds (yes, this topic is about flight within Class B airspace). Perhaps I lost track. Did he not say his clearance limit was outside Class B airspace? |
On 08/07/08 11:03, Steven P. McNicoll wrote:
Mark Hansen wrote: 1000' above the cloud? As I understand the cloud clearance requirements, in Class B airspace you just need to be clear of clouds (yes, this topic is about flight within Class B airspace). Perhaps I lost track. Did he not say his clearance limit was outside Class B airspace? How is that relevant? His question was about canceling IFR while still inside the Class B airspace, once he reaches VFR On Top conditions. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
How is that relevant? His question was about canceling IFR while still inside the Class B airspace, once he reaches VFR On Top conditions. The relevance is if he maintains the IFR clearance until he's outside the Class B airspace he doesn't cancel inside Class B airspace. |
On 08/07/08 12:18, Steven P. McNicoll wrote:
Mark Hansen wrote: How is that relevant? His question was about canceling IFR while still inside the Class B airspace, once he reaches VFR On Top conditions. The relevance is if he maintains the IFR clearance until he's outside the Class B airspace he doesn't cancel inside Class B airspace. The OP was asking specifically about the ramification of canceling his IFR clearance while still inside the Class B. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
The OP was asking specifically about the ramification of canceling his IFR clearance while still inside the Class B. Yes, and I asked him if his clearance limit was inside or outside of Class B airspace and he said it was outside. |
On 08/07/08 13:23, Steven P. McNicoll wrote:
Mark Hansen wrote: The OP was asking specifically about the ramification of canceling his IFR clearance while still inside the Class B. Yes, and I asked him if his clearance limit was inside or outside of Class B airspace and he said it was outside. My gosh, Steven. The OP said he was canceling while inside Class B and you said he needed to be 1000' above the clouds. Now because you have been caught making a mistake, you must try to twist the discussion around to obfuscate the fact. I'm out of this one. Good luck. |
Mark Hansen wrote:
My gosh, Steven. The OP said he was canceling while inside Class B and you said he needed to be 1000' above the clouds. Now because you have been caught making a mistake, you must try to twist the discussion around to obfuscate the fact. I believe I said I might have lost track of the thread. Obviously you did too. I'm out of this one. No kidding. |
| Thread Tools | |
| Display Modes | |
| Any Recommendations for Noise Cancelling Headsets? | Google Madness | Piloting | 10 | April 1st 07 07:39 AM |
| Any Recommendations for Noise Cancelling Headsets? | Google Madness | Piloting | 5 | March 30th 07 02:51 PM |
| Bravo | Mal[_3_] | Aviation Photos | 0 | March 15th 07 03:47 AM |
| Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 10:35 PM |
| Lightspeed Headset mic noise cancelling performance | CharlieBuda | Piloting | 2 | December 22nd 06 08:54 PM |
