Philippe wrote:
Hello, I want to place C85 piston inside an O200 engine. Do these pistons need any machining to fit? Thanks Are you replacing all 4 pistons ?? they need to weigh the same to prevent dynamic vibration. and have the same compression ratio. Jerry |
le mardi 10 août 2010 06:23, Jerry Wass s'est penché sur son écritoire numérique:
Are you replacing all 4 pistons ?? they need to weigh the same to prevent dynamic vibration. and have the same compression ratio. Yes, and I will balanced rods. The piston I have are within 0,5g before balanced for a pair, 1g for all 4. I expect to have rods plus piston pin plus piston balanced within 1g. But I don't have the annswer: Do C85 pistons need any machining to fit O200 stroke in an O200 cylinder. At this time I rebuilt a O200 with all new parts but crankcase, rods and rockers arms. -- http://www.youtube.com/v/k6AP4SbRHNo...s=1&rel=0 Philippe Vessaire Ò¿Ó¬ |
O200 overhaul | Philippe[_4_] | Home Built | 0 | May 30th 10 08:38 PM |
O200 titan cylinders | Philippe Vessaire[_3_] | Home Built | 7 | November 4th 08 06:10 PM |
O200 cylinder | Philippe Vessaire[_3_] | Home Built | 3 | October 19th 08 11:21 AM |
O200 engine | Philippe Vessaire | Home Built | 7 | August 17th 07 08:53 PM |
O200 nose | Philippe | Home Built | 0 | July 22nd 05 08:09 PM |
