Is there a nose hook modification for a standard cirrus
Old October 24th 17, 01:08 AM posted to rec.aviation.soaring
Frank Whiteley
Default Is there a nose hook modification for a standard cirrus
On Monday, October 23, 2017 at 11:12:44 AM UTC-6, kirk.stant wrote:
Gliders with CG hooks are kinda like airplanes with tailwheels; if you know what you are doing they are no problem and can be more fun (i.e. need more skill) than nose hooks or nose wheels.
BUT
They both can setup situations that can rapidly escalate out of control. Crosswinds, unbalanced wings dropping, poor aileron control at low speed, tall grass - you have to be aware of the system dynamics and prepared to cope.
Now if we had CG hooks on towplanes..!
Kirk
66
I have seen a concept sketch for a specialty tow plane, automotive powered, large prop driven by a reduction drive, and cg tow tow hook and twin boom tail. Only a few hurdles to overcome, like FAR's (allow experimental to tow) and/or certification (difficult) and limited market. Break even point would be about 200 builds. It could equal or beat on of these as a tow plane
https://en.wikipedia.org/wiki/SIAI-Marchetti_SM.1019
Keep the CG hook and buy a winch is easier and cheaper.
Winter's coming;^)
Frank Whiteley
nose section from salvaged standard cirrus. Scott Williams Soaring 1 May 27th 17 04:58 PM
Jantar standard SZD-41A C.G. hook Žiga Munda Soaring 3 November 24th 15 02:00 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Hook up an mini headset to a Vertex Standard VX150 or 210 radio Peter Soaring 2 July 3rd 06 04:49 PM
Nose hook addition Jack Soaring 2 April 29th 06 08:08 AM
