Not in front of my PC with SeeYou right now, but I used it for 15 years or more as a State Record Keeper as well as on the SSA's national badge/record committee to evaluate hundreds of flights. Once you figure out how to create a task (including setting the waypoint and start/finish configurations), you can easily assign that task to a flight and step through fix-by-fix. You don't necessarily have to use the stats from SeeYou; in many cases things like release fix/height were critical, and you needed to be able to point to a specific dot.
If you are in 2d mode and you have the IGC file loaded and the task assigned, you should be able to step through any part of the flight with both zoom (i.e. zoomed in) and individual fixes with the arrow key. PM me if you are still struggling; I might be able to video an analysis tongight. |
Speed triangle on ridge | Waveguru | Soaring | 7 | November 19th 13 04:42 PM |
WGC Day 11 Tasks Set | Duster | Soaring | 1 | August 16th 12 05:30 PM |
FAI triangle records speed question | Bruno | Soaring | 1 | June 6th 09 05:05 PM |
evaluating aircraft | GE | Owning | 14 | January 13th 06 12:17 PM |
Evaluating high-time airfames | Andrew Gideon | Owning | 5 | July 15th 05 07:31 AM |
