C85 and O200 piston
Old August 9th 10, 02:02 PM posted to rec.aviation.homebuilt
Philippe[_4_]
Default C85 and O200 piston
Hello,
I want to place C85 piston inside an O200 engine.
Do these pistons need any machining to fit?
Thanks
http://www.youtube.com/v/k6AP4SbRHNo...s=1&rel=0
Philippe Vessaire Ò¿Ó¬
Old August 10th 10, 06:23 AM posted to rec.aviation.homebuilt
jerry wass
Philippe wrote:
Hello,
Thanks
Are you replacing all 4 pistons ?? they need to weigh the same to
prevent dynamic vibration. and have the same compression ratio.
Jerry
Old August 11th 10, 06:47 PM posted to rec.aviation.homebuilt
Philippe[_4_]
le mardi 10 août 2010 06:23, Jerry Wass s'est penché sur son écritoire numérique:
Yes, and I will balanced rods.
The piston I have are within 0,5g before balanced for a pair, 1g for all 4.
I expect to have rods plus piston pin plus piston balanced within 1g.
But I don't have the annswer:
Do C85 pistons need any machining to fit O200 stroke in an
O200 cylinder.
At this time I rebuilt a O200 with all new parts but crankcase, rods
and rockers arms.
O200 overhaul Philippe[_4_] Home Built 0 May 30th 10 09:38 PM
O200 titan cylinders Philippe Vessaire[_3_] Home Built 7 November 4th 08 07:10 PM
O200 cylinder Philippe Vessaire[_3_] Home Built 3 October 19th 08 12:21 PM
O200 engine Philippe Vessaire Home Built 7 August 17th 07 09:53 PM
O200 nose Philippe Home Built 0 July 22nd 05 09:09 PM
