Nice FLARM antenna mount in ASG-29
Old April 6th 13, 12:42 AM posted to rec.aviation.soaring
Dave Nadler
Default Nice FLARM antenna mount in ASG-29
Easy to make and use, works well, see the update I posted he
http://powerflarm.us/powerflarm-installation-notes/
Enjoy,
Best Regards, Dave
Old April 6th 13, 02:51 AM posted to rec.aviation.soaring
Richard[_9_]
On Friday, April 5, 2013 3:42:45 PM UTC-7, Dave Nadler wrote:
Easy to make and use, works well, see the update I posted he http://powerflarm.us/powerflarm-installation-notes/ Enjoy, Best Regards, Dave
Quite a bit nicer and cleaner antenna installations at:
http://www.craggyaero.com/cables_&_antennas.htm
Richard
www.craggyaero.com
Old April 6th 13, 03:41 AM posted to rec.aviation.soaring
Sam Discusflyer[_2_]
HI Richard,
That looks clean... it doesn't look like the dipole that comes with the
brick either...
1-what antenna is it?
2-how is it mounted under the covers? on plastic frame?
Any difference between it and the dipole?
Stephen S9
Old April 6th 13, 03:49 AM posted to rec.aviation.soaring
HI Richard,
brick either...
Stephen S9
Old April 6th 13, 10:19 AM posted to rec.aviation.soaring
Ramy
Sorry, but I wouldn't call any of the installations in these photos "nice". not even close. Effective yes, but nice? I am glad I don't have carbon in my nose and can get 4 miles average range according to Flarm range analyzer by mounting the antenna in the nose of my 27a. Otherwise I would have looked for other antenna solutions than the dipole solutions shown in these photos.
Even with the dipole, I bet sufficient range can be archived by hiding half of it below the glare shield.
Ramy
Old April 6th 13, 04:10 PM posted to rec.aviation.soaring
Steve Koerner
Ramy,
That's exactly what I've thought. I would have put my Flarm antenna in the nose of my glider like you did except that space was already occupied by a transponder antenna. So, last fall I embarked on designing and modelling a dipole like antenna that is constructed of thin spring wire (visually unobstructive). It has a 4 element wire counterpoise that lives below the glare shield with a single vertical element above the glare shield. I'm using a small breakaway coaxial antenna which also comprises the mounting through the glareshield. I'm planning to attend the Perry contest so I should get data on how well it performs there.
I had in mind that I might manufacture this antenna as a commercial endeavor. However, when I disclosed the design to Flarm they had certain objections. The objection that I couldn't dismiss was that the Flarm radio circuit can be damaged by static discharge and the thin exposed element would increase that suseptibility.
Old April 6th 13, 04:24 PM posted to rec.aviation.soaring
Richard[_9_]
On Friday, April 5, 2013 6:41:15 PM UTC-7, Sam Discusflyer wrote:
HI Richard, That looks clean... it doesn't look like the dipole that comes with the brick either... 1-what antenna is it? 2-how is it mounted under the covers? on plastic frame? Any difference between it and the dipole? Stephen S9
Sam,
Three PowerFlarm antennas are shown:
All antennas fit to the panel cover with a bulkhead fitting then the antennas screw on to the fitting.
500103 1/4 wave rubber duck 3.4" with 6" ground plane 2' cable
500101 1/2 wave dipole 5" no ground plane required 2' cable
500102 1/2 wave rubber duck 2.3" with 6" ground plane 2' cable
Richard
www.craggyaero.com
Old April 6th 13, 06:39 PM posted to rec.aviation.soaring
JS
Agree with Ramy.
Using the same method - documented by Peter Kelly - in the nose of the 27.. But looking for a good combination for antenna #2. Perhaps another dipole like in Pete Alexander's 29. Only one pole is visible above the glare shield and it just sits in a grommet which would let go in an emergency.
Old April 6th 13, 10:49 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 4/6/2013 7:10 AM, Steve Koerner wrote:
Ramy,
Perhaps a small ball on the end like a transponder antenna? Or is it the
exposed wire that is the problem? The "classic" Flarm seems to have a
plain wire antenna with a small button on top.
email me)
FLARM antenna question (hindrance from metal) 2NO Soaring 19 March 12th 17 07:58 AM
Comm antenna distance from pilot? Becker flex antenna? [email protected] Soaring 3 January 16th 13 11:16 AM
Q: Position of external Flarm RF antenna on tow plane Aviat Husky A1 RuudH Soaring 5 December 20th 12 05:58 PM
Again with FLARM antenna questions. brianDG303[_2_] Soaring 0 July 23rd 12 06:35 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 07:53 PM
