Hybrid Arcus
Old April 1st 15, 12:38 PM posted to rec.aviation.soaring
Default Hybrid Arcus
Borrowing the hybrid technology from the automotive industry, a hybrid system has been developed and succesfully tested on an Arcus.
Energy is stored in a high capacity battery bank during thermalling and during cruise when lift is encountered below the current McCready setting. This energy is then used to extend the best L/D by almost 41%.
The system uses a 4.1KW brushless motor paired with an 14" fixed pitch prop that is mounted to the front of the arcus using the nose tow release as a hard point. As such, no modifications to the structure are required. Wiring to the motor are simply routed around the nose release back to the battery and the controller system.
Pictures of the installed system are at:
http://daziv.com/arcus/img_5333.jpg
http://daziv.com/arcus/img_5335.jpg
The computer controller is designed to optimize automatically the transition from regenerative energy storage to additional thrust production. The pilot can over-ride the system and use any stored energy available in a manner similar to a sustainer if needed.
A crowdfunding effort will be conducted today only so that this system can be developed for all other gliders. The current price target for the system is approximately $4,100 USD.
Old April 1st 15, 12:55 PM posted to rec.aviation.soaring
Hello,
I think it is definitely a very interesting proposition for increasing efficiency in cross country flying. However, where do you see your "niche" with this system? I don't think that competitions (regular or OLC) would allow this in sailplanes. I could definitely see a UAV system that might be interested in this sort of technology!
Best,
Daniel
Old April 1st 15, 01:07 PM posted to rec.aviation.soaring
Hello,
Best,
Daniel
April 1st Daniel
Old April 1st 15, 01:46 PM posted to rec.aviation.soaring
Hello,
Best,
Daniel
-_-
Isn't a bad idea though!
Best,
Daniel
Old April 1st 15, 04:03 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
The really great idea for getting high and staying high will be announced on April 20th. I bet it will cost $420.
Old April 1st 15, 04:18 PM posted to rec.aviation.soaring
Dan Marotta
snip
snip
Will that require eating brownies, Steve, or smoking something?
And what about us folks who don't have nose hooks? If I mount that
thing under the fuselage right in front of the wheel can I take off
vertically?
Dan Marotta
Old April 1st 15, 04:29 PM posted to rec.aviation.soaring
ND
Bahaha
Old April 1st 15, 05:07 PM posted to rec.aviation.soaring
Bruce Hoult
Hello,
Best,
Daniel
-_-
Not really.
The most efficient energy storage & release system for a sailplane is always going to be taking the energy as moar altitude. This would only be useful when there are huge gaps you can't cross at best L/D, but you don't mind wasting half an hour circling at cloudbase charging the battery.
Also, a fixed pitch prop (as listed) isn't going to do the job anyway. Gonna want different pitch for harvesting vs sustainer mode, not to mention feathered/folded when not in use.
Old April 1st 15, 08:44 PM posted to rec.aviation.soaring
Jim[_31_]
Karl, To save money and time you can match them with replacements from:
Bansbach Easylift of North America, Inc.
50 West Drive
Melbourne, FL 32904
Tel (321) 253-1999
Fax (321) 253-5546
www.easylift.com
You need to know the force, length open and closed. Also tell them the type of end connectors (eyelet, etc.).
-PC
Old April 1st 15, 09:18 PM posted to rec.aviation.soaring
I saw this Arcus in person. It does have a prop on the front.
Hybrid Engines?? sisu1a Soaring 16 March 15th 09 01:30 PM
The Best Hybrid Car For You n41beyha Piloting 0 November 27th 07 05:52 PM
bio-diesel hybrid future John T Home Built 9 September 2nd 05 02:22 PM
bio-diesel hybrid future John T Piloting 8 September 2nd 05 02:22 PM
bio-diesel hybrid future Martin Hotze Piloting 0 August 27th 05 02:42 PM
