NEW Sporting Code rules
Old October 15th 15, 10:15 PM posted to rec.aviation.soaring
Ian[_2_]
Default NEW Sporting Code rules
On 10/10/2015 12:20, Judy Ruprecht wrote:
7. SC3 Annex C Section 3.4 now allows a PR with pressure sensor (eg
Flarm) to have that pressure sensor ignored & the GPS altitude used.
This is the most significant change to the Sporting Code, for club
pilots, since the invention of GPS. Now it is possible to fly badges, up
to gold level, in any glider equipped with a Flarm. As the GPS altitude
can be used instead of the pressure altitude, there is no longer a
requirement for that Flarm to have a current calibration certificate for
the pressure sensor.
As many club pilots have access to club ships equipped with Flarm, they
can now arrive at their club on a weekend and go and fly badge flights
without first having to get hold of a calibrated FR - which might not be
readily available.
However the applicable country's National Association will have to do
their homework to put the necessary approvals in place to use Flarm as a
PR. This has already been done for a number of countries, and there are
sample approval documents for Flarm available in German, French and
English, which could easily be adapted by other country's National
Associations.
Sensibility is finally catching up with red tape...
Ian
Old October 16th 15, 01:20 AM posted to rec.aviation.soaring
Ramy[_2_]
readily available.
Associations.
Ian
Maybe I am missing something, but if GPS altitude can be used instead of pressure altitude, how can you verify that the pilot did not bust class A? The difference between pressure and GPS altitude can be close to 1000 feet near 18K. Same question goes for altitude gain and loss measurements.
Ramy
Old October 16th 15, 01:08 PM posted to rec.aviation.soaring
Bruce Hoult
readily available.
Associations.
Ian
GPS bounces around, especially in altitude due to not often having satellites near the zenith. But if you average it over 10 or 15 minutes then it's very accurate. if you're not moving.
Of course, gliders don't stay put for 10 or 15 minutes. But if you have a pressure altimeter then you know how much you went up and down at each GPS reading, even if the altimeter isn't calibrated or set to QNH. In fact you use the GPS to continuously calibrate the pressure altimeter. Whatever the average difference is between GPS and pressure attitude over the last 15 minutes, that's how much you should adjust the pressure altitude reading by. This compensates for both unknown QNH and unknown altimeter calibration at the same time.
That gives you accurate physical WGS84 altitude, which is perfect for task verification purposes of altitude gain or loss.
"Busting Class A" is a different matter as that's based on pressure level not actual altitude. For that, you need either a calibrated pressure altimeter (only), or your true altitude from the GPS+uncalibrated altimeter combo AND the area QNH.
(I don't know whether FLARM combines the GPS and pressure in the way described, but you'd certainly hope so .. it's not rocket science)
Old October 16th 15, 01:37 PM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
=20
used.
=20
This is the most significant change to the Sporting Code, for club=20
u=
p=20
altitude=
=20
can be used instead of the pressure altitude, there is no longer a=20
fo=
r=20
=20
they=
=20
flights=
=20
b=
e=20
readily available.
=20
do=
=20
as
a=20
are=
=20
and=20
English, which could easily be adapted by other country's National=20
Associations.
=20
=20
Ian
=20
of
A?
feet
near 18K. Same question goes for altitude gain and loss measurements.=20
satellit=
v=
p=
r=
u=
a=
min=
T=
t=
he same time.
task
n=
altimet=
combo
AND the area QNH.
descri=
I believe that for it's anti-collision function Flarm uses GPS Altitude,
smoothed by pressure altitude. i.e. pressure altitude is used to remove the
'bounces' of GPS altitude. In this way, all Flarm use the same datum. Call
it Flarm Altitude if you wish.
But that is for it's anti-collision function. Not to be confused with what
is in the IGC file.
In the IGC file, Flarm records both Pressure and GPS altitude.
The word calibrated is a bit of a misnomer. What that really means is that
a calibration chart is available.
IF there is a question of airspace infringement, the claim can be frozen
until a new calibration chart can be produced. This should only occur in
rare cases where the margin is small.
The GPS altitude can still be used for other aspects of the claim.
NEW Sporting Code rules [email protected] Soaring 6 October 15th 15 09:20 PM
NEW Sporting Code rules [email protected] Soaring 12 October 15th 15 12:19 AM
Sporting Code Question Peter von Tresckow Soaring 4 June 27th 12 08:08 PM
Sporting Code Question Gary Emerson Soaring 6 March 24th 08 07:46 PM
Why does the Sporting code require stephanevdv Soaring 2 October 17th 04 07:38 PM
