GPS approach step-down fixes
Old May 6th 06, 07:53 PM posted to rec.aviation.ifr
Default GPS approach step-down fixes
As far as I can see, step-down fixes on GPS approaches are always defined by
a distance to the threshold. Are there exceptions?
Do GPS approaches exist with waypoints (forming part of the approach
sequence) between the FAF and the runway threshold waypoint? Or is it
guaranteed that after passing the FAF, my distance-to-waypoint will always
be the distance to the threshold?
Counter-examples useful. References to publications guaranteeing no
counter-examples even better!
Thanks
Julian
Old May 6th 06, 08:11 PM posted to rec.aviation.ifr
Thanks
Julian
The criteria are evolving and changing. You have to take each procedure
as it is charted and as it appears in your database.
Old May 6th 06, 09:34 PM posted to rec.aviation.ifr
"Julian Scarfe" wrote in message ...
Thanks
Julian
Did you mean strictly "distance to the threshold"?
Where the Missed Approach Point is short of the threshold,
stepdown fixes are likely to be defined by distance to the MAP.
In Colorado, here are a few examples which illustrate that:
KCAG (Craig) GPS Rwy 7
KDRO (Durango) GPS Rwy 2
KEGE (Eagle County) GPS-D
KHDN (Hayden) RNAV (GPS) Y Rwy 10
KLXV (Leadville) GPS Rwy 16
KMTJ (Montrose) GPS Rwy 17, GPS Rwy 35
KRIL (Rifle) GPS Rwy 8, GPS Rwy 26
Most of those stepdown points are defined only by distance,
but at least in the case of Hayden, ZULON is a named stepdown fix,
at 1.9 nm to RAPVE, which is the MAP located 1 nm from the runway.
Old May 7th 06, 03:12 AM posted to rec.aviation.ifr
Thanks
Julian
As I said:
"The criteria are evolving and changing. You have to take each
procedure as it is charted and as it appears in your database."
Old May 7th 06, 11:27 AM posted to rec.aviation.ifr
"John R. Copeland" wrote in message
You're right, I meant distance to MAP, not distance to threshold. So
perhaps that changes the question into whether there are waypoints on the
approach between the FAF and the MAP.
OK, good example. So when I pass INEDE (the FAF) inbound on that approach,
what does my distance-to-waypoint read? 3.5, counting down to ZULON, or 5.4
counting down to RAPVE?
Julian
Old May 8th 06, 05:19 AM posted to rec.aviation.ifr
Julian
I've run several other examples through the GNS480 simulator,
and they all have computed a smooth glide path from the FAF to the MAP,
displaying nothing regarding the named stepdown fixes.
The distance counts down from the FAF to the MAP, as in your supposition.
I don't know of any approaches near me with suitable stepdown fixes
to try actually flying one for real.
But previously I've found the simulator to be very faithful to the actual equipment.
If you have the GNS430/530 simulator, try running some approaches on it.
It might behave differently, since it would not supply vertical guidance.
Old May 9th 06, 09:16 AM posted to rec.aviation.ifr
Thanks, I'll give it a go.
Julian
Old May 9th 06, 11:59 PM posted to rec.aviation.ifr
"Peter" wrote in message ...
The other question I would ask here is whether an FAA approved IFR GPS
is *capable* of continuously displaying the distance to the MAP,
during the flight from the FAF to the MAP, if there are *any*
waypoints between the two.
I don't think it is. I don't think it's possible to have
FAF X Y Z MAP
and somehow force the GPS to display the distance *to the MAP* while
one is flying past X,Y,Z.
The GPS will always display the distance to the next waypoint in the
database.
In other words, I don't think it's possible to get the GPS to produce
a DME-like distance readout.
One way to achieve a distance readout to some waypoint which is past
the current one would be to have a sort of "invisible" attribute on a
waypoint (in the GPS database) causing the GPS to ignore it for the
distance calculation.
Yes, it is possible for at least some GPSs to do what you doubt.
I don't have a TSO-C129 GPS to compare with,
but my TSO-C146 unit will display distance to MAP, ignoring stepdowns,
but possibly only when it can compute an uninterrupted glide path to MAP.
In that case, even though named stepdown fixes exist, they aren't used.
That's the behavior I've seen in the U.S.; I don't know the rules behind it.
Of course, in the UK, with EGNOS not yet available,
TSO-C146 units could not compute that glide path,
so I shouldn't try to guess what they'd do without augmentation.
But I'd expect them to revert to TSO-C129-like behavior.
I think Julian may experiment with a Garmin 430/530 simulator,
and he'll surely tell us if he turns up behavior different from the GNS480.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
IFR Approach questions Roy Smith Instrument Flight Rules 2 November 7th 05 03:11 AM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 05:03 PM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
