Temporarily deviating from IFR
Old April 10th 07, 08:49 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mxsmanic
Default Temporarily deviating from IFR
You're flying happily over the desert in your small plane, in bright, clear
weather, on your IFR flight plan. You notice a plume of smoke a short
distance away at your nine o'clock, and looking more carefully, you see what
looks like a stranded car with some people standing around it. You'd like to
investigate just to see if it might be someone who needs help.
Given that you're on an IFR flight plan and under ATC control, how do you
handle this? I presume you can't just tell ATC that you're going to swing
south and drop to 2000 feet for a while to check something out. Do you ask
ATC to vector you towards the stranded car? Do you cancel IFR to go take a
look? Is there a way of suspending IFR temporarily so that you can leave your
planned route and altitude and check out the source of the smoke? What's the
procedure?
On a related note (whence the crosspost to r.a.p.), has this ever happened to
you? That is, have you ever seen something that looked like a possible case
of people in distress on the ground and decided to go over and take a look
and/or report it to ATC?
Old April 10th 07, 08:57 PM posted to rec.aviation.ifr,rec.aviation.piloting
Newps
procedure?
Sure, you can....well nevermind.
Old April 11th 07, 12:44 AM posted to rec.aviation.ifr,rec.aviation.piloting
Al G[_1_]
"Newps" wrote in message
clear
what
like to
swing
ask
a
your
procedure?
happened to
case
look
Oh Yea, the old "Burning Car in the Desert" trick.
Al G
Old April 10th 07, 10:41 PM posted to rec.aviation.ifr,rec.aviation.piloting
Danny Deger
"Mxsmanic" wrote in message
clear
what
to
Simple -- request deviations in the direction needed by the distance needed,
request an altitude block, and request the correct number of 360 degree
turns.
The call would be something like, "Request deviation 10 miles north of
course, altitude block of 2,000 to 3,000 feet and 3 360s to investegate a
possible car in distress." But, if the weather is VFR, "Cancel IFR" might
be the best call.
Danny Deger
ask
a
your
procedure?
to
case
Old April 10th 07, 10:08 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mxsmanic
Danny Deger writes:
be the best call.
Can you reactivate an IFR flight plan after cancelling it and continue from
some point within the plan, or do you have to file a brand new one if you want
to return to IFR.
I take it there's no such thing as "suspend IFR."
Old April 11th 07, 12:03 AM posted to rec.aviation.ifr,rec.aviation.piloting
Danny Deger
Danny Deger writes:
might
be the best call.
from
want
to return to IFR.
You are correct. Once you cancel, you have to refile.
Danny Deger
Old April 11th 07, 12:37 AM posted to rec.aviation.ifr,rec.aviation.piloting
Jose
If you are VMC and expect to remain so, you could request "VFR on top"
and a course deviation. If they don't have to hold a hard altitude for
you, they may be more flexible in granting deviations.
Jose
Get high on gasoline: fly an airplane.
Old April 11th 07, 03:03 PM posted to rec.aviation.ifr,rec.aviation.piloting
James M. Knox
Mxsmanic wrote in
from some point within the plan, or do you have to file a brand new
one if you want to return to IFR.
Certainly not in those words. There *is* such a thing as a compound
flight plan. This is used where you want to transition from IFR to VFR
or VFR to IFR at a certain point. However, the very few folks I know
who have ever tried to file such a thing have always run into problems
(controller doesn't understand, thing gets munged in the computer,
etc.). Usually easier to file TWO flight plans, one VFR and one IFR,
that swap off at some point. Or, more commonly, just request the change
in the air.
There is also a /D+xx that can be filed. It's used (at least in theory)
when you want to "suspend" the IFR flight for a few minutes at an
airport, usually to pick up or drop off a passenger. You file the route
something like CWK V17 TPL/D+15 V17 ACT where TPL is the Temple Texas
airport and you are going to be on the ground 15 minutes or less.
The problem is, it almost never works. Controllers have forgotten what
it means, and they don't like to have to keep the airspace sanitized
while you are on the ground. They would again much prefer you to simply
file TWO flight plans (in this case, one to TPL and one from TPL).
For the case you described that started this thread, the usual case is
simply to request deviations as needed. But IFR is really *not* for
sightseeing. [That's why airlines fly IFR always, now. They used to
always "sightsee" in good weather, until the day two of them ran into
each other over the Grand Canyon. After that the rules changed.]
James M. Knox
TriSoft ph 512-385-0316
1300 Koenig Lane West fax 512-371-5716
Suite 200
Austin, Tx 78756
Old April 11th 07, 04:12 PM posted to rec.aviation.ifr,rec.aviation.piloting
Newps
James M. Knox wrote:
Mxsmanic wrote in
You guys sure make this hard. The IFR system is not that rigid.
Old April 11th 07, 06:37 PM posted to rec.aviation.ifr,rec.aviation.piloting
Mxsmanic
Newps writes:
But there does seem to be a gulf between what is theoretically and formally
allowed and what actually works in practice.
Temporarily deviating from IFR Mxsmanic Piloting 23 April 17th 07 04:30 PM
High Voltage Light On (Temporarily) three-eight-hotel Owning 15 April 28th 06 07:21 PM
FAA has temporarily withdrawn the proposed Sport Pilot rule Larry Dighera Piloting 2 March 27th 04 06:23 AM
Standard Cirrus web site temporarily offline Jim Hendrix Soaring 1 January 21st 04 07:09 PM
