Touch up urethane for a ash-31
Old February 2nd 20, 04:17 PM posted to rec.aviation.soaring
RR
Default Touch up urethane for a ash-31
Any sugestions for a urethane paint for touch up on a 31? I had a little bit, but then waited to long to use it and the paint has separated, and the hardener has dried up. Need to buy some new, and looking for a sugestion for a place to buy some, in quantities less than gallons.
Old February 2nd 20, 05:30 PM posted to rec.aviation.soaring
Craig Reinholt
Contact Rex Mayes and ask him.
Williams Soaring 530-473-5600
Old February 2nd 20, 08:47 PM posted to rec.aviation.soaring
kinsell
For minor touchups, gelcoat works fine. Cheaper/safer/easier to use.
Old February 2nd 20, 08:57 PM posted to rec.aviation.soaring
Per Carlin
Car paint repair shops can put 2k PU in spraycans, all you need to know is the Ral number of the paint.
Old February 2nd 20, 09:05 PM posted to rec.aviation.soaring
I use Sherwin Willaims 3rd Dimension acrylic urethane , mostly because that is what my paint supplier stocks. PPG Concept is almost the same and seems to be the default among most refinish shops.
Matching is a trial and error deal. Tinting is usually a small amount of yellow and a tiny bit of black.
Ships vary. They are not all the same. I understand Rex has said he goes to the paint store for each ship.
Take a winglet and see if your paint store can read and match.
Good luck
UH
Old February 2nd 20, 10:02 PM posted to rec.aviation.soaring
Andrzej Kobus
RR, PPG Concept, please send me an email and I will tell you where to get it locally, AK
Reducing PPG Concept Urethane [email protected] Soaring 23 January 28th 16 10:33 AM
Urethane Paint Jonathan St. Cloud Soaring 44 November 20th 15 11:48 AM
urethane 2K paint [email protected] Soaring 1 February 5th 14 12:30 AM
GPS for the Out Of Touch brian whatcott Piloting 9 October 15th 09 09:28 AM
DEN touch n go without a fee? Ron Lee Piloting 22 September 3rd 06 10:57 PM
